Configure device policies
Device policies apply to the managed device itself. User settings apply to a signed-in managed user, and managed guest session settings apply only inside that session. Choose the correct policy area before editing.
Before you begin
- Put test devices in a pilot organisational unit.
- Record the current value and the expected result.
- Confirm that your admin role can edit device settings.
Change a device policy
- Open Settings → Device settings and select the pilot organisational unit. Browse a category or search by setting name or description.
- Check the source: Default, Inherited (the parent unit is named) or Locally applied.
- Change the setting, or select Inherit from parent to remove that local override. Review all pending changes on the page, then select Save.
- Check the result on a pilot device after its next policy fetch. An offline device will not apply a change immediately.
Understand inheritance
With a Kiosk-only licence, you can edit device settings marked Applies to Kiosk. Other device settings require Business+. User and managed guest session settings require Business+; Basic devices do not receive policies.
Current setting lists: Device, User, Kiosk, Managed guest session. Choose the session type first, then look up the setting name or policy ID.
Verify a policy
- Open Devices → Managed devices.
- Find a pilot device in the target organisational unit.
- Open the device and check Last Policy Sync.
- Keep the device online and trigger a normal restart only when the policy requires it.
- Confirm the expected behaviour on the device.
If a policy does not apply, see Troubleshooting checklist.
Common policy locations
| Goal | Console path |
| Restrict who can sign in | Settings → Device settings → Sign-in settings |
| Control guest mode | Settings → Device settings → Sign-in settings |
| Configure updates | Settings → Device settings, then search for update |
| Configure user browser behaviour | Settings → User settings |
| Configure managed guest sessions | Settings → Managed guest sessions |
| Deploy apps and extensions | Apps → Apps & extensions |
| Configure kiosk power and accessibility | Settings → Kiosk settings |
Change-management checklist
- Apply one related group of settings at a time.
- Test on at least one representative device.
- Record the organisational unit and previous value.
- Check device behaviour after policy sync.
- Expand to a larger unit only after the pilot succeeds.
- Device inventory and monitoring, find devices and verify their state.
- Troubleshooting checklist, diagnose common device problems.
